2012 vw jetta remote start causing code
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133500
Printed Date: April 12, 2026 at 11:44 AM
Topic: 2012 vw jetta remote start causing code
Posted By: scaf77
Subject: 2012 vw jetta remote start causing code
Date Posted: February 02, 2013 at 5:56 PM
Hi all,
I installed a remote start in a 2012 Jetta. Everything works and no check engine light. When I put a scan tool on it I get fault code 3444 Implausible signal. I called tech support for the evo_all and they said I had the wrong firmware. I updated the firmware and same thing. To solve the problem I uninstalled the evo and used a 555u so there would be no can bus communication and I still have the same problem. If I start with the key I dont get the code, remote start and the code comes up. sorry for the long first post but Im pulling my hair out at this point. Thanks in advance for any help you can give.
Posted By: soundnsecurity
Date Posted: February 02, 2013 at 10:18 PM
sounds like you may have missed one of the main ignition wires. a lt of times a car will start and run even if you miss a wire but because that wire normally powers something, the car might be interpreting that missing power signal as something being broken or maybe a main fuse is blown. new cars have sensors on everything so its easy to cause a fault code for minor mistakes.
Posted By: howie ll
Date Posted: February 03, 2013 at 9:36 AM
2 x ignition wires?
Posted By: scaf77
Date Posted: February 03, 2013 at 11:17 AM
I connected to BLACK/ purple ignition wire @ ignition harness. I'm not aware of another ignition wire.
12v - RED / yellow @ VESCM
Starter - RED / black @ ignition
Ignition - BLACK/ purple @ ignition
Accessory - BLACK/ red @ ignition
Date Posted: February 03, 2013 at 12:16 PM
can you see any other wires at the ignition harness? maybe there's a wire that is not mentioned in the diagram. sometimes they leave wires out that arent necessary for the car to start and run but if there are more wires at the ignition harness then obviously they must do something.
Posted By: howie ll
Date Posted: February 03, 2013 at 12:51 PM
2nd. starter??
pur/yel (SS1), pur/blk (SS2) (push-button start).
Resistive.
Start system button, 4 pin plug, pins 3 and 4.
Also and I apologise if you did but did you wire up the ACC?
Posted By: scaf77
Date Posted: February 03, 2013 at 1:29 PM
Hi,
I did power the ACC BLACK/ Red @ ignition. I could be wrong but I believe the second starter is only for push button cars.
Posted By: howie ll
Date Posted: February 03, 2013 at 1:41 PM
No, you're quite right, just trying to cover all possibilities.
Posted By: a454nova
Date Posted: September 05, 2013 at 12:36 PM
I know it's a few months old but thought I'd post this in case it helps.
https://www.12voltdata.com/forum/viewtopic.php?f=307&t=8090
