Parking Light problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13358
Printed Date: May 14, 2026 at 1:11 AM
Topic: Parking Light problems
Posted By: SmaDoc
Subject: Parking Light problems
Date Posted: May 09, 2003 at 6:16 PM
Having problem figuring out how to make my parkinglights flash when the siren chrips. my alarm has the parking light output, but ive tried everything imaginable and nothing works, i saw the diagram ( https://www.the12volt.com/images/addlfwo.gif ) for making the lights flash with the siren chrip, but that didnt work too well, the siren signal goes off and on too fast for the lights to gain their full brightness. I cant figure out what the round thing in the diagram is, the one that has the X and L on it, with the x being hooked to pin 30 on a relay, and the L being hooked to the parkinglights. The only thing i could think of is that the thing with the X and L is a flasher unit, tried one from another car, but that didnt help any. Kinda at a loss for now. Although its not really needed, I would just like to get the parking lights to flash with the siren like they're suposta. Other problem i have is the trunk release button and aux button seem to be reversed. if i push the trunk button, aux 1 output triggers, if i push what i assume is the aux button on the 2way remote, the trunk release wire triggers.  My alarm/remote start/keyless entry unit is from Delta   Pro 5005 Combo, which as far as i can tell is the same as the commando pro 5005 combo, other than label differances, and maybe wiring which would explain some things i guess.Any help or info here would be appreciated.
Thanks,
Sam
Posted By: pinchy
Date Posted: May 18, 2003 at 5:56 PM
I think the round thing in the diagram is a turn signal flasher.
Posted By: riversphoenix
Date Posted: July 01, 2003 at 6:12 AM
i just installed my 5005 and the parkinglights output from the white wire doesnt work either..As far as your aux and trunk outputs the trunk release is the Aux1..I have a truck W/ shaved handles and no trunk. I use the aux1/trunk for my driver door actuator. I am still trying to find a use for the Whole lock and unlock part of the system..I am debating ifi will send back this brain for one w/ working lights.
Steven Michael
Date Posted: July 01, 2003 at 6:21 AM
P>S> here is a manual that will make yor life easier https://www.crimestopper.com/techweb/InstructionBooks/ComboSystem/cs2013-op-inst.pdf
Steven Michael
Posted By: riversphoenix20
Date Posted: July 13, 2003 at 9:06 AM
I just solved my parking light problem maybe yours can be the same prob..Insude the brain module there are a set of jumper that determine + or - output to the prking lights..I fidled w/ the jumper and all of a sudden i had an output..I think the jumpers are just not connectiong properly out of the box..
