04 05 dodge ram truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133756
Printed Date: May 15, 2026 at 10:50 AM
Topic: 04 05 dodge ram truck
Posted By: ramon2001
Subject: 04 05 dodge ram truck
Date Posted: March 02, 2013 at 8:37 PM
anyone please help, just installed scytek 777 alarm on 04 dodge truck four doors. alarm activates, meaning it locks and unlocks. when alarm is triggered i deactivated. when i open the door the factory alarm comes on. has to be deacticated with key in door. all doors have diodes. lock is 820 ohms and unlock is 330ohm with relays. what am i missing. how do i deactivate factory alarm? please help. im frustrated...i will check out tomorrow. thanks in advance
------------- RAMON
Posted By: yellow_cake
Date Posted: March 02, 2013 at 9:44 PM
The factory alarm wire is PURPLE / light blue driver kick panel (harness coming from door). The same wire will arm and disarm based on the resistor value.
Hook up your factory alarm disarm wire from the skytek to this wire.
But first figure out which year the truck is because 04 & 05 show different resistors values.
Check https://readyremote.com/main.asp for resistor values.
