black widow bw 10000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133824
Printed Date: May 16, 2026 at 8:06 AM
Topic: black widow bw 10000
Posted By: kramer826
Subject: black widow bw 10000
Date Posted: March 10, 2013 at 5:47 AM
Hi ,I am after a wiring diargam or installation manual for the BLACK WIDOW BW-10000 alarm system.My brother had one installed in his vechicle and is having intermittant starter faults.As it is a black wire alarm system I would like to have a wiring diagram or pinout of the alarm system.If someone has this could you please post me a link as to where to locate it thankyou in advance
Date Posted: March 10, 2013 at 5:48 AM
Car is HQ Holden Monaro 1972 thankyou
Posted By: howie ll
Date Posted: March 10, 2013 at 7:14 AM
Intermittent starter faults would point to a faulty or failed connections to an off-board starter relay.
Having said that neither I or any other pro would fail to point out that we are dealing with a 40 year old car.
Have you tried Googling that Black Widow device?
Date Posted: March 10, 2013 at 8:49 PM
Hi thanks for your reply,yes I have googled for that device but cannot locate any information,hence the post,I am an electronics technician of over 30 years experience so am quite capable of fault finding,just trying to locate a pin-out for the all black wiring plug,I cannot find the starter relay ,I suspect it may be on board the alarm module now, I measured only 5 volts on the starter solenoid so yes i realise it is either a bad connection or possibly burnt relay contact ,it happens intermittently so the information would be handy to fault find without having to tear apart the wiring unnecessarily...
thank you for your help
