bulldog antenna i don’t have one.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133888
Printed Date: April 01, 2026 at 5:00 PM
Topic: bulldog antenna i don’t have one.
Posted By: fiddlebick
Subject: bulldog antenna i don’t have one.
Date Posted: March 18, 2013 at 2:33 PM
Installing an older rs 1200 on my Mommy in laws truck. It is an older used unit and it is missing the antenna. I am sure I can order a replacement from bulldog, but I have the vehicle today and tomorrow, and I want to install it now, as I have the time. Will the unit respond to the keypad at zero range, basically point blank signal? Does anyone know if radio shack has the components available so I could make my own antenna? Or is that even possible? Thanks guys, john.
fiddlebick
Posted By: kreg357
Date Posted: March 18, 2013 at 2:59 PM
How long is the Yellow wire on the 16 Pin connector?
Date Posted: March 18, 2013 at 3:27 PM
The yellow wire measures approx 16-17 inches.
fiddlebick
Posted By: howie ll
Date Posted: March 18, 2013 at 3:46 PM
Just copy it and see.
Posted By: howie ll
Date Posted: March 18, 2013 at 3:47 PM
16" = 400cms = around 400mhz so it should be OK.
Posted By: howie ll
Date Posted: March 18, 2013 at 3:49 PM
No forget the last post, its size in mm x 300,000 for frequency in Mhz.
Length should be around 12"
Posted By: howie ll
Date Posted: March 18, 2013 at 3:50 PM
Wrong again, 9".
Posted By: kreg357
Date Posted: March 18, 2013 at 4:53 PM
Can't remember but the RS1100 doesn't have an antenna, just a short wire that is supposed to be straight and heading upwards.  The RS1200 had a long antenna that went to the windshield but the RS1200 "E" models had something different.   A call to Bulldog Tech Support should sort it out, they are very helpful
Date Posted: March 18, 2013 at 4:55 PM
Howie,  I don't understand your post at all...just copy what?
fiddlebick
Posted By: howie ll
Date Posted: March 18, 2013 at 5:47 PM
Some early units simply used a piece of wire, about 12" should suffice to get you some sort of reception for now.
