2002 dodge caravan r/s problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133976
Printed Date: March 30, 2026 at 12:35 PM
Topic: 2002 dodge caravan r/s problem
Posted By: bassaholic123
Subject: 2002 dodge caravan r/s problem
Date Posted: April 03, 2013 at 9:59 AM
Hello all,I just finished installing an Avital 5103,got everything working,but the only problem I'm having that the parking lights and radio are staying on after the remote starter times out,any help would very appreciated.
Alex B.
Posted By: offroadzj
Date Posted: April 03, 2013 at 10:56 AM
The radio is staying on because of the RAP (retained accessory power). I am not 100% sure, but the parking lights may be tied in there as well. There are 2 options you have here:
1) Let it time out and wait to see if they turn off after some time. I've seen most Chryslers time out at around 5 minutes max and some Chevy's time out at upwards of 15-20 minutes. If it times out, then as long as you don't mind it for the few times it might happen, then you don't have to do anything.
2) You can also use the factory re-arm output of the remote starter tied into the driver's door pin of the vehicle. This will pulse the driver's door pin and make the vehicle think the door was opened, which will turn off the RAP.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: April 03, 2013 at 12:07 PM
Will try your suggestion and see if they do time out after a while.Thank you Kenny.
