proximity sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134089
Printed Date: April 02, 2026 at 2:36 AM
Topic: proximity sensor
Posted By: jsotomar
Subject: proximity sensor
Date Posted: April 22, 2013 at 2:30 PM
Hi all,
I installed a Autopage RS-665 r/s to my 02 Explorer. Everything works. Now I would like to install a proximity sensor. The alarm came with a shock sensor that plugs in to the brain.
To install the proximity, do I just tap into the RED / BLACK/ GREEN/ blue wires? Do I have to cut the green wire from the shock? Do I need to have another aux port? I would like the warn & full-out modes for both sensors.
Alarm installed:
AutoPage C3 RS-665
Proximity Sensor wanted:
Omega AU-94TM
Would this be replacing both sensors or is it just a re-named proximity?
Directed 508D
Thanks! ------------- I love Cheese.
Posted By: howie ll
Date Posted: April 22, 2013 at 2:58 PM
The 508d is compatible, a dual zone prox.
You will need 4 x 1N4004 diodes and the wiring is thus:-
add_sensor.bmp------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
Posted By: jsotomar
Date Posted: April 22, 2013 at 3:38 PM
Ok, thanks! that was fast  ------------- I love Cheese.
Posted By: jsotomar
Date Posted: April 23, 2013 at 8:12 AM
One more question. I have installed the siren that came with the alarm. Now I wish to add the factory horn with a pulse in combo with the siren. With chirps, warn, and full-out. Do I need to add a relay for this? Do I tap into the parking lights wire dioded?. As of now, I dont have the relay installed for the dome light, this wire is just grounded (White Wire - Dome Light supervision).
Just a note, prior to this alarm install, my factory OEM keyless entry does pulse the horn when a door is opened. The Autopage only uses the siren, not horn.
Thanks in advance.  ------------- I love Cheese.
Posted By: howie ll
Date Posted: April 23, 2013 at 11:00 AM
You need two relays.
a) Brown siren output, branch out with an inline 1N4004 diode, band towards relay, to 86.
Good grounds to 87 and 85
30 to yellow/light green or yellow/light blue, steering column loom or CSM.
White to second relay with an inline diode, 1N4004 with the band away from the relay.85
12V+ constant 5 amps fused to 86 and 87.
30 to blue/black dome supervision, driver kick panel.
Posted By: jsotomar
Date Posted: April 23, 2013 at 11:03 AM
Ok, thanks for all the info!
