ford transit mk6 deadlock cable colour?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134188
Printed Date: April 05, 2026 at 2:10 PM
Topic: ford transit mk6 deadlock cable colour?
Posted By: wrexad07
Subject: ford transit mk6 deadlock cable colour?
Date Posted: May 10, 2013 at 11:34 AM
Hello,
I recently swapped out an old alarm on my Mk6 Transit RHD to a Clifford G5 Concept 470. The old alarm had no AUX outs so wasn't able to set time delays like you can the clifford so was never able to make the alarm fob activate the deadlocks
I have read a post on here about making the deadlocks lock with the alarm fob https://www.the12volt.com/installbay/forum_posts.asp?tid=127826&tpn=1&PN=1 But this is for a Mk7 and i didn't know if the wiring/central locking system was different as the Mk7 uses a canbus system.
Howie drew up a wiring diagram on that thread https://www.the12volt.com/installbay/uploads/3F2_relay_1.bmp which is easy enough if i knew the cable i have to cut into.. so my question is does anyone know which cable i am looking for? or what colour it is coming out the central locking module?
thanks for any help!
Posted By: howie ll
Date Posted: May 16, 2013 at 7:38 AM
YELLOW
