viper alarm not unlocking doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134289
Printed Date: April 08, 2026 at 2:24 AM
Topic: viper alarm not unlocking doors
Posted By: supertoby78
Subject: viper alarm not unlocking doors
Date Posted: May 28, 2013 at 7:23 PM
I searched and couldn't find a direct answer to my question.
I've owned this 91 Suburban for 4 months. The previous owner had a Viper alarm installed. The door locks stopped working today and the blue led on the window mounted antenna (I think it's an antenna) blinks 3 times. I think that means the issue is door switch related. The power locks work if I hit the button on the doors. Also the dome light stays on. I had to pull the fuse so the battery wouldn't drain.
I'm not sure what Viper alarm I have. I guess my question is does the wire for the door locks go to just one power lock button like the drivers side? If it is a loose wire or something like that why would the dome light stay on like the door is open? Could I just pull the power cable off of the battery for 15 minutes or something to let the system reset?
Date Posted: May 28, 2013 at 8:05 PM
Disregard. The fuses were all fine the first time I checked. After messing with it for 1/2 hour I double checked all the fuses and the horn/dim fuse blew. Replaced it and now it works. Don't know what blew it.
