what kind of alarm is best for an integra
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13436
Printed Date: May 13, 2026 at 7:32 AM
Topic: what kind of alarm is best for an integra
Posted By: p_mot99
Subject: what kind of alarm is best for an integra
Date Posted: May 11, 2003 at 9:52 PM
what is the best alarm for an acura integra. and i would like to know how easy it is to install an alarm with remote start. by the way my car is manual tranny.
------------- p_mot99
Posted By: draasch
Date Posted: May 12, 2003 at 5:22 PM
pretty much any alarm will do. alot will depend on what type of options you want to install in the car. ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: auex
Date Posted: May 12, 2003 at 5:58 PM
I was going to say "One that works" but seeing that it is a manual and wanting remote start limits you. Just make sure that you get an alarm that checks to make sure the e-brake is on (at least). Now for safety, it is not recommended to install a remote start on a manual, even if you trust yourself because you don't know how other people park your car, and even if you parking brake is on doesn't mean that your car won't go anywhere. Also if you go through with it make sure they install a defeat toggle switch so you can disable the remote start for when you go into service( i got a good story about this, let's just say a local auto painter got a drive through).
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
