g40rs issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134395
Printed Date: April 08, 2026 at 3:41 AM
Topic: g40rs issue
Posted By: frd1419
Subject: g40rs issue
Date Posted: June 18, 2013 at 12:23 PM
I installed a G40RS in a 99 Discovery II and the strangest thing is happening. When the temperature outside warms up the range of the remote decreases. You almost have to be 3" from the antenna to work. When the temperature is under 70 or cool off the interior of the car to under 70 all works well. I've remote will work from 40" away. Anyone home across this type of problem before.
Posted By: racerjames76
Date Posted: June 19, 2013 at 12:33 PM
Not familiar with the system or the vehicle, but if I had to harbor a guess, I would suspect the antenna has a broken or cracked solder joint somewhere. I am sorry but I can not offer any advice on a fix other than to replace the antenna assembly. Good luck  ------------- To master and control electricity is perfection. *evil laugh*
Posted By: pts760
Date Posted: June 19, 2013 at 4:47 PM
Just out of curiosity, does this happen in the same location where the vehicle is parked every time or does the vehicles location not affect the functionality issue? I had a customer that had range issues when it was parked in the same location every time.
------------- I drink current, eat ohms, and bleed voltage
Posted By: howie ll
Date Posted: June 19, 2013 at 6:15 PM
Police/fire/other utilities with transmitting antennae will also block your signal.
Posted By: frd1419
Date Posted: June 19, 2013 at 10:48 PM
We have tried The vehicle in different locations.
Posted By: pts760
Date Posted: June 20, 2013 at 6:20 PM
Have you tried a new brain? Maybe there is a internal thermistor that is causing the unit to malfunction.
