5704 external sensors not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134490
Printed Date: April 06, 2026 at 8:18 AM
Topic: 5704 external sensors not working
Posted By: 95impyss
Subject: 5704 external sensors not working
Date Posted: July 06, 2013 at 7:43 PM
Hello. a buddy of mine just finished up an install of a Viper 5704v alarm system. everything is now functioning. except for the external sensors. He has installed a tilt sensor, a glass break sensor and the external shock sensor that came with the alarm system. Neither of these 3 sensors cause the alarm to produce warn away chirps, full alarm or any reporting to the remote. we have set the sensitivity of the shock sensor to its max setting. and can see the LED illuminate when the car is subjected to a hit of the wheel, door or steering wheel.
I have a bad feeling that the brain is damaged or defective. is there any kind of factory reset that can be performed to solve this issue? or is there a setting that needs to be adjusted to allow these sensors to communicate properly?
any information is greatly appreciated.
thanks in advance!
Posted By: pts760
Date Posted: July 07, 2013 at 10:22 AM
did you use diodes to isolate all the sensors from each other?
------------- I drink current, eat ohms, and bleed voltage
Posted By: 95impyss
Date Posted: July 07, 2013 at 9:49 PM
Thanks for the reply.
We have not installed any diodes. Tbere are no added diodes to the system. Both the shock sensor and the audio sensor are plugged into a factory harness that has 2 sensor plugs. And the tilt sensor is on a modified harness. The harness provided with the tilt sensor was only a 3 pin. This alarm requires a 4 pin. So I connected the 12v+, ground and the wire the sensor reports on to a 4 pin.
I installed the same alarm with the same sensors wired like this in my car about a year ago with no problems. Which is what has had me stumped as to why this install is not working for him.
I didn't do any of the wiring on this install except for the modified tilt sensor harness. Is there a chance that something wired wrong during the install could cause this issue?
Remote start works, and all the other triggers work, hood pin, and dome light.
Posted By: 95impyss
Date Posted: July 07, 2013 at 9:59 PM
I am curious as to where one would put the diodes. On the reporting wires?
Posted By: pts760
Date Posted: July 10, 2013 at 2:44 PM
Which sensor is plugged into a port by itself?
Posted By: 95impyss
Date Posted: July 13, 2013 at 10:38 AM
The tilt sensor is on its own port. The shock sensor is piggybacked with the audio sensor.
Posted By: pts760
Date Posted: July 15, 2013 at 10:42 AM
Disconnect the shock sensor piggy backed with the audio sensor and see if you get any response from the tilt sensor.
