evo all not programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134491
Printed Date: April 06, 2026 at 10:14 AM
Topic: evo all not programming
Posted By: Raymond4646
Subject: evo all not programming
Date Posted: July 06, 2013 at 9:25 PM
I have a 2013 dodge dart soldered all connections for vehicle/evo/viper 5904. Ive installed over a dozen remote starts in the past never used an evo. All wires are tagged correctly. Going thru the Key Data Acquisition and CAN-Bus programming the unit will not exit from the solid yellow light after only inserting key into the ignition barrel without turning on. Any ideas? The directions are very specific. Holding the programming button, then inserting plug. Once lights turn yellow remove finger from programming button. Then install wires and press programming button 4x. once done flashing and solid yellow insert key. Doesnt change. Thank you for any assistance.
Date Posted: July 06, 2013 at 10:22 PM
Got the unit to work finally! Needed a software update that was recently released.
Posted By: lucasoil4u
Date Posted: July 10, 2013 at 10:17 AM
Glad to hear you got it figured out.
