2007 tundra crew max limited sunroof
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134537
Printed Date: April 07, 2026 at 9:09 PM
Topic: 2007 tundra crew max limited sunroof
Posted By: brianh
Subject: 2007 tundra crew max limited sunroof
Date Posted: July 14, 2013 at 3:18 PM
Trying to figure out if I can use a relay to close sunroof on lock. You can turn the key (driver doora)and open/close the sunroof. I was wondering if anyone was able to extend the door lock pulse to make this happen? Or I could use a latched output from my alarm to control a relay to close it.   Anyone had any luck with this? If so your help would be greatly appreciated.   Thanks in advance,   Brian
Posted By: pts760
Date Posted: July 15, 2013 at 10:52 AM
I would use a latched output from the alarm instead of using wiring at the key cylinder. This way the doors wont lock/unlock when you control the sunroof. You will have to add two relays to two separate latched outputs which will allow you to open and close the sunroof.
I drink current, eat ohms, and bleed voltage
