clifford alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134556
Printed Date: April 08, 2026 at 4:32 PM
Topic: clifford alarm
Posted By: markmills2000uk
Subject: clifford alarm
Date Posted: July 17, 2013 at 3:05 PM
im installing a clifford concept 650 in my ford capri and im stuck on the imobilizer wires, i got the alarm so i can arm and disarm it and that works fine but i have no power at my ignition, the power is going into the clifford alarm but when i disarm the alarm the power doesnt come back out of it.
anyone have any ideas,i thought it might be a sticky relay and i had a few other clifford alarms lieing about so plugged in a 950 but that is doing the same.
dont suppose anyone knows which numbered wires inside the alarm are which., they are numbered 1-8 just so i can be sure i got them right,
Posted By: howie ll
Date Posted: July 19, 2013 at 2:23 PM
Simple, you have to find the wire marked "Ignition, key side" that goes to the ignition key side of the ignition wire, all the others will fall into place after that.
There is a test procedure on the bench to work out which is which.
