audiovox prestige aps 45b
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134746
Printed Date: April 28, 2026 at 5:03 PM
Topic: audiovox prestige aps 45b
Posted By: dougand3
Subject: audiovox prestige aps 45b
Date Posted: August 16, 2013 at 9:38 PM
I bought an 03 Hyundai Accent 4 dr with above unit/add-on PDL actuators. No remote came with car. I bought a proper remote. I can program LOCK and it works just fine. But can't get UNLOCK programmed to work. Tried 10x. The remote shows RF signal on Lock, Unlock, Option, so I think it's fine.
Can the brain go out on just one channel? Some other programming technique I should try? Thanks, Doug
Posted By: triniforever
Date Posted: August 18, 2013 at 6:29 PM
How are you programming the remote?
------------- triniforever
Posted By: dougand3
Date Posted: August 18, 2013 at 8:08 PM
https://www.voxxintlcorp.com/docs/common/APS45B/APS45B_PG.pdf
On page 2, starting with 1(a) to 7.
Posted By: racerjames76
Date Posted: August 20, 2013 at 12:35 PM
There was also a tech note recently that may or may not apply here. Has to do with the antenna picking up interference during programming. Basically you follow the guide but when pressing the transmitter buttons the transmitter must be more than 10 feet from the antenna.  worth a shot if nothing else works.. ------------- To master and control electricity is perfection. *evil laugh*
Posted By: dougand3
Date Posted: August 21, 2013 at 9:17 PM
Thanks, racerjames. But I lost patience. I yanked 45B out and going to put an el cheapo Chinese unit in. Fleabay vendor has kit: brain, wire harness, 2 x key-chain remotes for $12.98. That's a lot cheaper than 1 key-chain remote for 45B. If it goes bad, I'll get another kit and change brain out. Time will tell.
