2013 fusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134762
Printed Date: April 29, 2026 at 3:55 AM
Topic: 2013 fusion
Posted By: pentavolvo
Subject: 2013 fusion
Date Posted: August 19, 2013 at 7:27 PM
Has anyone done a remote start on a 2013 fusion, it is a different key then the fords I am used to. They are factory flip keys. No bypass info available. Not sure if this is an 80 bit and the pktx will work. I will even do key in box but don't know if its 80 bit or some new encryption deal
Posted By: Mike M2
Date Posted: August 19, 2013 at 8:38 PM
If it's a key in box install what dooes it matter?
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: August 19, 2013 at 8:54 PM
Going to need to program a spare key not going to give up the key/remote flip blade deal
Posted By: cmk0808ny
Date Posted: August 20, 2013 at 10:21 AM
I do Ford dealers all the time. No bypass for the 13 Fusion. Went to lin bus for immobilizer. Only way is to bury a factory key. No other key will program. No 80/40 bit keys, nothing will program. Might be 120 bit now on that car.
Other option is to get the Ford accessory one button starter. Has to be activated by the Ford dealer.
Date Posted: August 20, 2013 at 12:47 PM
Thanks I appreciate the info
