2006 mercury mariner
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134800
Printed Date: April 08, 2026 at 10:04 PM
Topic: 2006 mercury mariner
Posted By: joe363
Subject: 2006 mercury mariner
Date Posted: August 28, 2013 at 9:35 PM
Hi..I'm putting in a Autopage rs730. I see I have to connect to the battery. Do I have to run two feed wires? Or can I run one 10 gauge and connect both 30 amp leads to that? Also I red one post that said to connect to the ignition 12 volt but drop the 30s to 10 amp fuses..that seems like not the right thing to do..what would you do?
Posted By: triniforever
Date Posted: August 30, 2013 at 8:06 AM
One wire from the battery should be fine fo power everything up
triniforever
