help ford probe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13504
Printed Date: May 12, 2026 at 9:40 AM
Topic: help ford probe
Posted By: SERGDL2000
Subject: help ford probe
Date Posted: May 13, 2003 at 10:12 PM
I need some Help to install an alarm on a 1993 FORD PROBE with factory keyless I already have the Car diagram this is my question.....
should I pull out  the hole factory module?? or there is another way to upgrade without pulling it?
Sergio...
Posted By: draasch
Date Posted: May 13, 2003 at 10:31 PM
you can add an aftermarket alarm and leave the factory unit in there.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: May 13, 2003 at 10:39 PM
OK
leaving the factory unit without touching any wire ???
can u tellme how to upgrade??
Sergio...
