Avital 4003 OEM Key Fob Programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135117
Printed Date: May 14, 2026 at 4:12 PM
Topic: Avital 4003 OEM Key Fob Programming
Posted By: nogdog
Subject: Avital 4003 OEM Key Fob Programming
Date Posted: October 21, 2013 at 9:33 PM
Hi I have a 2004 Dodge Neon. I just installed a Avital 4003 remote start with a DB-ALL. This setup uses the oem remotes. I'm not seeing any info in my manual on how to program these. Help Please
Posted By: smokeman1
Date Posted: October 21, 2013 at 10:06 PM
According to the little bit of info I could find, your car must have a factory keyless entry system. Below is from a different web site:
https://www.remotestartexperts.com/dei-avital-4003-addon-remote-starter-module.html
Here's how it works. It is "connected" to your vehicle's power door locks such that it is activated with your factory keyless entry remote's lock button. Pressing your remote's lock button "once" locks your doors, pressing it a "2nd time" acctivates the Avital 4003 Remote Starter. If your factory keyless entry remote now "confirms" your doors are locked when you press it a 2nd time (with a horn honk and/or flashing your parking lights), you can re-program the Avital 4003 so that it "activates" when you press your factory remote's lock button a "3rd time" (instead of the 2nd time).
I have never tried one of these systems. Even though you went D2D, it might help to list your other wired connections.
------------- When all else fails, Read the Instructions
