could i double diodes the trunk trigger?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135164
Printed Date: May 13, 2026 at 10:13 PM
Topic: could i double diodes the trunk trigger?
Posted By: bad_dude
Subject: could i double diodes the trunk trigger?
Date Posted: October 28, 2013 at 2:44 PM
Hello everyone,
I installed my alarm system in the summer of 2011. It has a 2 way remote. I think the system is the Crime Guard 750i6. Recently I have been getting false alarm. It would go off by itself.
So when it goes off the hood is flashing. So I disarm it, then arm it, but then it flash the door as fault. I then disarm it, and arm it, then it flash the hood as fault. I replaced the hood switch and the problem still persist. Before I take apart my car and replace the brain, I remove the connector to the hood pin switch, and this stops the false alarm.
I am wondering if the diodes I isolate the trunk and hood triggers have gone bad? I really don't want to tear the dash apart to reach the brain to replace the diode. Could I add another diode nearer to the hood pin switch? Would this work to isolate the hood trigger?
Thanks.
Posted By: blanx218
Date Posted: October 28, 2013 at 4:07 PM
If you remove the connector to the hood pin and the problem stops then you have a problem with the hood pin. It could need adjusted to ensure its at the proper height to be pressed down completely when the hood is closed.
Posted By: auto enhancers
Date Posted: October 29, 2013 at 9:01 AM
sometimes the easiest answer is actually correct. If the problem still there after adjusting the hood pin I would check the trunk pin
