power door locks with alarm install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13520
Printed Date: May 12, 2026 at 6:49 AM
Topic: power door locks with alarm install
Posted By: Zich
Subject: power door locks with alarm install
Date Posted: May 14, 2003 at 10:25 AM
I'm trying to figure out how to correctly install a power door lock system with my alarm. The door lock system I'm looking at has a 5-wire driver door actuator, and 2-wire actuators for the other 3 doors.
I have the following outputs on my alarm:
Door lock N/O, door lock n/c, door lock com
Door unlock n/o, door unlock n/c, door unlock com
Priority unlock output
First off, I don't exactly understand how this 5-wire thing works. All the actuators plug into a "brain" that comes with the lock system that I assume is just the relay system described on this site. If I want the alarm to lock/unlock all doors, I can just tap door lock com and unlock com into two wires on the 5-wire actuator, I believe.
However, I'd like to install the priority lock, and in this case the alarm says to wire the door lock/unlock wires to the driver's door actuator, and the priority unlock wire to the unlock wire for the rest of the system.
I'm at a loss as to which wires to tap into... Can anyone help? Btw, here is the system I'd like to use, and my alarm is Alpine SEC-8028:
https://www.partsexpress.com/pe/showdetl.cfm?&User_ID=13044997&St=3959&St2=58049915&St3=55289494&DS_ID=3&Product_ID=9676&DID=7
Posted By: jaxman
Date Posted: May 14, 2003 at 4:48 PM
What car it is ?
Posted By: Zich
Date Posted: May 14, 2003 at 6:38 PM
Well I'm installing the locks myself, so the car doesn't really matter, but it's a 1993 camry
