alarm speaker
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135399
Printed Date: May 24, 2026 at 4:54 AM
Topic: alarm speaker
Posted By: southwest2118
Subject: alarm speaker
Date Posted: November 27, 2013 at 10:31 PM
i have a avital 3503L but missing the horn/speaker ...will any horn work? if i go to the savage yard how can i test it?
Posted By: i am an idiot
Date Posted: November 28, 2013 at 9:48 AM
I am not sure if Avital uses a speaker or a siren. Very few manufacturers use a speaker. You need to do some research and see what they use. If a speaker is used, the output from the alarm brain will be an audio signal. If it has 12volts DC coming out of the brain, it requires a siren. A siren is a speaker with the audio generator and an amplifier built into the speaker housing. If you determine that it uses a siren, go to the salvage yard and bring a 9 volt battery with you. Cut the wires from a siren and touch the appropriate wires to the terminals of the battery. If it makes siren sounds, it is working. It will not be as loud as it should, since you are supplying a 12V device with only 9V.
Date Posted: November 29, 2013 at 12:34 AM
I checked the output of the siren and its about 5v? does that sound right? what does that mean?
Date Posted: November 29, 2013 at 5:52 AM
AC or DC?
Posted By: itsyuk
Date Posted: November 29, 2013 at 12:06 PM
avital's website shows a 5303 model but no 3503L or 3503.....
are you sure you have the model number correct?
being a directed product it probably uses a revenger 6 tone siren... unless its an avital made before directed bought them out.
some pictures might be nice
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Date Posted: November 29, 2013 at 6:30 PM
posted_image
posted_image
the inside cover says 2011?
Posted By: itsyuk
Date Posted: November 30, 2013 at 2:27 AM
look on page 4 of that owners manual and see if it says "Revenger" under "Whats Included" like the picture shows.
If it does, then skip the salvage yard and buy a new Revenger Siren from ebay. they dont cost much.posted_image
yuk
Posted By: itsyuk
Date Posted: November 30, 2013 at 2:39 AM
I found the owners manual for the 5303 alarm on avitals site. i couldnt find the L model so thats why its important to check your manual to see if it describes the same siren....
SO!!!.... here is an idea ...
If you can confirm its the Revenger....Make a $10 donation to the12volt board PM me you mailing address and i will mail you a brand new in the box revenger soft chirp 6-tone siren.
yuk
Date Posted: November 30, 2013 at 9:07 AM
posted_image
Posted By: itsyuk
Date Posted: December 01, 2013 at 2:28 AM
the pic you showed should list ALL things included with your system but it said nothing about the module, harness, valet switch, LED etc....
have you installed this system yet?
if not, shoot (a better lit) picture of all the parts that you have. I've noticed your manual says "keyless entry system" which would NOT include a siren and is NOT an alarm.
it instead should have a wire (it might be brown) that is noted in the installation manual (not the owners manual) as Horn "-" which means it is intended to avtivate a relay by grounding the coil of the relay causing that relay to honk your car's horn.
yuk
Date Posted: December 01, 2013 at 7:17 PM
OK i found a option in the programming to change output to horn, now not only will the full alarm make the horn sound but it also does the chirp with horn. Thanks guys
Posted By: itsyuk
Date Posted: December 01, 2013 at 9:29 PM
cool
yuk
