starter wont disengage after pljx
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135408
Printed Date: April 06, 2026 at 1:18 AM
Topic: starter wont disengage after pljx
Posted By: abrrymnvette
Subject: starter wont disengage after pljx
Date Posted: November 29, 2013 at 11:40 AM
I installed a DEI 5101 remote start and it would start my truck just fine for a second then die because of the Passlock2. So, I installed a PLJX bypass and the truck would then start, but never stop the starter? I didn't hook up the keysense wire to the PLJX. I read somewhere I didn't need to. Im thinking I grabbed the wrong wire out of the 5101 to the brown wire on the bypass?
Truck is a 2002 Silverado with 5.3 V8.
Posted By: chev104275
Date Posted: November 29, 2013 at 11:55 AM
Sounds like a tach issue. Where did you grab tach from ?
------------- If i Can't Install it I Don't need it Joe
Date Posted: November 29, 2013 at 12:06 PM
From the white wire at the pcm. Can't remember the exact pin number.
Date Posted: November 29, 2013 at 12:37 PM
Did you learn tach to the system ? Did it recognize the signal ?
Date Posted: November 29, 2013 at 12:54 PM
I did not, I must have overlooked that part in the instructions. Is that for the remote start or for the bypass? Ill look into it. Thanks.
Date Posted: November 29, 2013 at 1:04 PM
I believe it's start the truck with the key. Within 10 seconds press and hold the programming button the led should light up when a valid tach signal is present.
Date Posted: November 29, 2013 at 1:22 PM
Ah, I didn't do that. Thanks. I'll do that and report back. Appreciate the help.
