2001 avalon remote start key sense
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135488
Printed Date: April 08, 2026 at 3:36 PM
Topic: 2001 avalon remote start key sense
Posted By: mrmaxp0wr
Subject: 2001 avalon remote start key sense
Date Posted: December 07, 2013 at 4:22 PM
Car: US Spec 2001 Toyota Avalon XLS with Factory Security
RES: Viper 4806V and 556U Bypass Module
Wiring is detailed below the post.
What doesn't work:
HVAC has no power when remote start is used. When remotely started, as soon as the key is inserted, the engine dies and the remote start points to a brake input as the cause.
History:
I carefully researched the wiring tables for my car for hours prior to installing, including the listing found here and on several other sites. I removed the un-used wires on the RES harnesses by de-pinning them to prevent any confusion and clean up the install.
I installed the 5-wire lock/unlock system with a relay in the driver's door and everything works well.
What works:
Horn, locks, parking lights and AUX (trunk) output function as they should. Vehicle will lock/unlock, remote start and remote shut down. Brake press will shut down engine. Hood switch will prevent start if hood is open. Everything functions normally when using a key. Factory alarm arms/disarms with lock/unlock and during RES.
Other notable behavior:
During a RES, if the two conductor lead that contains the RED / YEL key sense wire is disconnected from the ignition cylinder, I can insert the key and successfully drive away. I can also start the car normally and then activate the RES allowing me to remove my key and exit the vehicle while still running.
Testing I've done:
Verified all wiring below matches my install. If the RED / YEL key sense wire is given a ground while RES is running the car, the engine dies - exact same behavior as if key is inserted. I've also run pin 2 of the RES harness to 12V constant with no behavior change.
At this point I'm stuck and desperately ask for expert assistance. What am I doing wrong?
Thanks!
Remote Start 8 Pin Harness:
[PIN #] - [RES Description] - [RES Color] : [Car Description] - [Car Color]
1 - 12V Constant - RED / BLK : 12V Constant - WHT/BLU
2 - REMOVED 87a of Flex Relay - *See testing above
3 - Ignition 2 - PNK/WHT : Ignition 2 - WHT/RED (Smaller Gauge of the two)
4 - 12V Constant - RED : 12V Constant - WHT/BLU
5 - Starter Output - VIOLET : Starter - BLK/WHT
6 - 12V Accy Output - ORG : 12V Accy - WHT/GRN
7 - 12V Constant - RED / WHT : 12V Constant - WHT/BLU
8 - Ignition I/O - PNK : Ignition - BLK/ORG
Main 6 Pin Harness:
1 - 12V Constant - RED : 12V Constant - WHT/BLU
2 - Ground - BLK : Chassis Ground
3 - Horn - BRN : Horn - GRN/BLK
4 - REMOVED Light Insol. WIre
5 - Parking Lights - WHT : Parking Lights - PNK
6 - REMOVED Ground When Armed
Aux/Shutdown 24 Pin Harness
1 - REMOVED Ignition 2 (low) Output
2 - Defroster (low) BLU/WHT : Defroster Relay - RED / BLK
3 - Trunk (low) - RED / WHT : Trunk Relay - BLU
4 - REMOVED Dome Light
5 - RES Output (low) - DRK BLU : 556U Bypass Input - BLU
6 - REMOVED AUX 3
7 - REMOVED AUX 1
8 - REMOVED AUX 4
9 - Hood Pin - GRY : Hood Pin - BLK
10 - Horn Input - BLU : Horn - GRN/BLK
11 - REMOVED Activation Input
12 - Tach - VIOLET/WHT : Tach - BLK
13 - Ground - BLK/WHT : Chassis Ground
14 - REMOVED Factory Alarm Disarm
15 - (-) Door Input - GRN : Door Switch - RED / BLU
16 - EMPTY
17 - REMOVED Ignition Output (low)
18 - REMOVED (+) Door Input
19 - REMOVED AUX 2
20 - Brake Shutdown - BRN : Brake - GRN/WHT
21 - REMOVED Starter Output (low)
22 - REMOVED Wait to Start (low)
23 - REMOVED Accy Output (low)
24 - REMOVED Alarm Arm Output (low)
On the car side - key sense (RED / YEL) is currently un-tapped as it prevents RES. See testing notes above.
Posted By: pts760
Date Posted: December 08, 2013 at 2:44 PM
You could try to interrupt the key sense wire with a relay. The key sense would only be interrupted during remote start and act normally with the remote start disengaged.
85: "5 - RES Output (low) - DRK BLU (diode isolate relay and 556U) or re-pin "17 - REMOVED Ignition Output (low)" no diodes required then.
86: Fused 12v constant
87A: Key side of RED / Yellow Key sense wire
30: Vehicle side of RED / Yellow Key sense wire
87: N/A
I drink current, eat ohms, and bleed voltage
Date Posted: December 08, 2013 at 5:55 PM
I appreciate the feedback!
While I understand the concept, the need to interrupt the key sense wire seems to cover the main problem.
Has anyone installed a remote start on a 2000-2004 Avalon XLS with factory security? What changes to my current wiring would you suggest to resolve my two problems?
Posted By: pts760
Date Posted: December 08, 2013 at 6:58 PM
For your HVAC problem I would check "12V Accy Output - ORG : 12V Accy - WHT/GRN" connection at the ignition harness. You have the correct wire from the remote start to the vehicles ACC wire. Test the WHT/GRN wire during remote start to verify your connection.
This circuit powers the HVAC during remote start. The vehicle will still remote start without this wire being powered but the HVAC won't work.
Also, I've worked on toyota's around that year with factory keyless/security that have caused me issues. I usually follow the harnesses to the brain and disconnect the OEM keyless/security brain.
The vehicles starter wire has to be jumped in the harness if disconnected or the vehicle won't start. You can tell if a vehicle has this by noticing that the ignition harness has a T-harness. This may save you from wiring a relay in the key sense circuit.
