2012 gmc sierra premium
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135565
Printed Date: April 12, 2026 at 9:19 AM
Topic: 2012 gmc sierra premium
Posted By: ziggyb222
Subject: 2012 gmc sierra premium
Date Posted: December 18, 2013 at 10:37 AM
Doing a premium package Sierra this weekend and want to know what is a good bypass module to use...I have done most of these with a simple key in the box and hooked the doorlocks direct..but I understand the premium package are multiplexed????
Posted By: chev104275
Date Posted: December 18, 2013 at 11:47 AM
If you have the programming cable then I Would go With a idatalink ads al ca flashed with the gm10 firmware. Give you pretty much everything. But you need to be able to use klon. If not then you could use the gm3 firmware with the ads ring to reduce the power consumption.
