2007 jeep patriot ,dei545t
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135574
Printed Date: April 12, 2026 at 7:33 PM
Topic: 2007 jeep patriot ,dei545t
Posted By: raypeebles
Subject: 2007 jeep patriot ,dei545t
Date Posted: December 19, 2013 at 7:04 PM
Looking for headlight trigger wire,any help as to which wire?
Date Posted: December 21, 2013 at 2:12 PM
Surely someone has wanted to add automatic headlights to a jeep patriot,compass or dodge caliber?
Posted By: smokeman1
Date Posted: December 21, 2013 at 3:20 PM
From a kreg357 post:
For vehicle wiring, here are some sources :
Here is a link to Bulldog Security : https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Here is a link to Ready Remote : https://www.readyremote.com/main.asp
Here is a link to AudioVox : https://techservices.audiovox.com/AccessRequest.aspx Sign-up & info is free.
------------- When all else fails, Read the Instructions
Date Posted: December 21, 2013 at 11:23 PM
None of these sites have info for headlite wiring,i need to trigger head,park and dash lites.
Posted By: yellow_cake
Date Posted: December 22, 2013 at 12:21 AM
There is no "trigger wire" for the headlights. The headlight switch communicates with the TIPM through data. You will have to tap into the headlight wires using relays.
Left: Low beam WT/DB. High beam WT/PK.
Right: Low beam VT/RD. High beam WT/GY.
These wires come from the TIPM (Totally Integrated Power Module) to the head lamps.
Date Posted: December 22, 2013 at 12:27 AM
But I realized that won't light up your dash lights as the cluster also receives communication through data.
If you are comfortable with taking the headlight switch apart and see if it's possible to mimic it's operation by wiring in relay, that may be your only option to triggering the headlights..
