Alarm Wiring for 2013 Honda CR-V
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135576
Printed Date: April 12, 2026 at 9:29 PM
Topic: Alarm Wiring for 2013 Honda CR-V
Posted By: atish
Subject: Alarm Wiring for 2013 Honda CR-V
Date Posted: December 19, 2013 at 11:19 PM
I have a install in the morning on a 2013 Honda CRV and the newest on the forum is from 07. I plan on using a pkall but I have a dball if necessary. The 13 column isn't on the pkall diagram but does show when I search on xpresskit. If only neg locks and only remote start keyless I would like to use the pkall over the dball. I would think xpresskit wouldn't show pkall would work if it didn't on 13 probably the same install as a 12. Just reaching out to see if anyone can get a wiring diagram and I will post how it goes when Im done.
Thank you guys as always,
Adam Tish
TNT Rides
Posted By: yellow_cake
Date Posted: December 20, 2013 at 3:59 AM
Posted By: kreg357
Date Posted: December 20, 2013 at 5:44 AM
Fortin lists the Key-OverRide-ALL for the 2013 Honda CR-V, using the same install diagram and vehicle wires as the 2012 CR-V, so the PK-ALL should work.
Posted By: atish
Date Posted: December 21, 2013 at 1:07 AM
Thank you yellowcake for the info, I ended up finding it and the color were the same.
As always I appreciate the info Kreg. I ended up using a pkall and it worked great. Overall actually a pretty easy install.
You guys are all amazing!!
