Intermittent Starter Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13558
Printed Date: May 12, 2026 at 10:32 AM
Topic: Intermittent Starter Problem
Posted By: john8700
Subject: Intermittent Starter Problem
Date Posted: May 15, 2003 at 6:18 AM
I installed a Hornet 554T into a 2003 Land Rover Freelander.  I did not wire in the starter disable, the 554T arms and disarms the factory alarm.  There have been 2 occasions that the car would not crank with key or remote start (it was like car was in drive or the starter was disabled by the alarm).
By the time the car is towed to the dealer it starts and the dealer cannot find a problem, and of course is blaming the aftermarket alarm/remote start.  Does anybody have any ideas what could cause this or what things I could look for when this happens again?
Posted By: john8700
Date Posted: May 15, 2003 at 6:26 AM
Sorry about the first post, I cut and pasted and it didnt work so well.  Here is how it should have looked.
I installed a Hornet 554T into a 2003 Land Rover Freelander.  I did not wire in the starter disable, the 554T arms and disarms the factory alarm which has the starter kill.
There have been 2 occasions that the car would not start with the key or remote start (it would not crank, lit was ike the starter was disabled by an alarm or the car was not in park.  By the time the car is towed to the dealer it starts and the dealer cannot find a problem, and of course is blaming the aftermarket alarm/remote start.
Does anyone have any ideas what could cause this or what things I could look for when this happens again?
Posted By: floaterr
Date Posted: May 20, 2003 at 10:22 PM
Next time it won't start try shifting into Neutral. Maybe the cutoff switch on in the neutral position is going bad. Possibly during the towing the steering column is shifting and the switch starts working again.
Good luck
