08 ford f 150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135629
Printed Date: May 16, 2026 at 3:20 PM
Topic: 08 ford f 150
Posted By: yellow_cake
Subject: 08 ford f 150
Date Posted: December 27, 2013 at 7:40 PM
The 08 lists the 12v constant as yellow/lt. green (un-fused) @ fuse box behind glove box, 1 pin terminal.
However, the 07 which is the same generation truck and all other wiring is the same; but the 12v constant is listed at the ignition harness lt. GREEN/ purple (20A).
My question is why would they want you to get the 12v constant from the fuse box? Can I still use the 12v in the ignition harness for a remote start? Or will the parking lights + cause an extra load that the ignition constant wasn't meant to have?
Posted By: dasbogie
Date Posted: December 27, 2013 at 7:59 PM
You will be alright at the ignition switch for constant power.
Advanced
Date Posted: December 27, 2013 at 8:53 PM
Perfect, thanks.
