door lock wiring for honda civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135774
Printed Date: April 08, 2026 at 8:43 PM
Topic: door lock wiring for honda civic
Posted By: myhonda1
Subject: door lock wiring for honda civic
Date Posted: January 10, 2014 at 12:17 AM
Hi all,
I am trying to install an Avital 2101L keyless entry system in my 1998 Honda Civic.
I am not sure how to wire the door locks, and and am hoping someone can assist.
On the Honda's keyless receiver 16-pin connector, I have:
B9: Unlock (all doors)
B10: Lock (output)
The Avital 2101L has the following connections:
H1/5 Lock #30 Common (Output)
H1/6 Lock #87A Normally Closed
H1/7 Lock #87 Normally Opened (Input)
H1/8 Unlock #30 Common (Output)
H1/9 Unlock #87 Normally Open (Input)
Can someone help me make the connections please?
Also, 12V is not available on this Honda connector. Can someone recommend the best place to grab it?
Thanks!
Posted By: kreg357
Date Posted: January 10, 2014 at 1:50 PM
H1/5 Lock #30 Common (Output) GREEN / WHITE (TYPE B) @ BLUE PLUG IN DRIVERS KICK PANEL H1/6 Lock #87A Normally Closed Not Used H1/7 Lock #87 Normally Opened (Input) Chassis Ground H1/8 Unlock #30 Common (Output) GREEN/ ORANGE (TYPE B) @ BLUE PLUG IN DRIVERS KICK PANEL H1/9 Unlock #87 Normally Open (Input) Chassis Ground H1/17 Unlock #87A Normally Closed Not Used
Here is one location for +12V constant power : 12 VOLT CONSTANT WHITE (+) @ IGNITION SWITCH HARNESS
Here is the info for the H1/10 White Parking Light wire ( set to (+) output ) : PARKING LIGHTS ( + ) RED / BLACK (+) IN DRIVERS KICK PANEL
------------- Soldering is fun!
Posted By: myhonda1
Date Posted: January 10, 2014 at 1:59 PM
Thanks Kreg357!
Why didn't you use the two pins on the Honda that I listed?
Can you be more specific about where the blue plug is located?
Posted By: kreg357
Date Posted: January 10, 2014 at 2:42 PM
The Blue Plug is located in the Drivers Kick Panel. This is the area below the dash, left side, just in front of the drivers door. This plastic panel might have a few fasteners holding it in place, but generally just pulls off. Ideally, you should have a Digital Multi Meter to locate and verify these wires ( and all wires ) prior to making your connections.
For me doing a remote start w/keyless entry install, this location and these standard Type B door locks wires are easy to get at and exactly what the after-market system is designed to interface with. ------------- Soldering is fun!
Posted By: myhonda1
Date Posted: January 10, 2014 at 2:59 PM
Thanks!
Can I use the two pins I specified? I would prefer to use those because they are at the green connector that contains other connections. That green connector is the one that used to plug into the factory radio.
If I can use those two pins, would the connections be the same as you've specified?
Posted By: kreg357
Date Posted: January 10, 2014 at 3:09 PM
Assuming the wire colors are the same and they test correctly with the DMM, you should be OK. Here is the door lock info from Audiovox, which seems to corroborate your info :
Power Unlock GREEN/ ORANGE (-) BEHIND RADIO "GREEN PLUG", ABOVE FUSE BOX OR AT ANTI-THEFT MOD PowerLock GREEN / WHITE (-) BEHIND RADIO "GREEN PLUG", ABOVE FUSE BOX OR AT ANTI-THEFT MOD ------------- Soldering is fun!
Posted By: myhonda1
Date Posted: January 10, 2014 at 3:27 PM
Thanks!
The wire colors are the same, so it looks like we are good.
Where is the Ignition Switch Harness ( for constant 12V) that you mentioned ?
Posted By: bl4ck3d0ut
Date Posted: January 10, 2014 at 3:31 PM
At the ignition switch..
https://www.9thgencivic.com/forum/attachments/electrical/2904d1329531487-diy-remote-start-alarm-pictures-img_0212.jpg
Posted By: kreg357
Date Posted: January 10, 2014 at 3:35 PM
The Ignition Switch Harness is plugged into the ignition switch. You will probably have to remove the lower steering column cover if you can't identify this wire as it leaves the steering column and continues under the dash area.
Posted By: myhonda1
Date Posted: January 10, 2014 at 3:58 PM
Thanks!
Do you know if the constant 12V can be picked up at the factory alarm connector?
Do you have a pin out for that connector? It is green and is located in the area behind that radio.
Posted By: myhonda1
Date Posted: February 01, 2014 at 7:05 PM
In case anyone is interested, here are the final connections - it works! - Thanks to those that helped, it is much appreciated!
The Constant 12V came off of the Alarm Connector. It was connected to H/1 Red (12V Constant Power) on the Avital 2101L
Pin on Green Connector
on '98 CivicAvital 2010L
2 (Trunk Latch Switch) H/18 RED / WHT (Channel) Trunk Release
6 (Ignition Switch On,12V) H/15 YLW Switched Ignition Input
8 (Dome Light) H/4 BLACK/ White Dome Light Supervis. Output
9 (Unlock All Doors) H/8 BLU/BLK Unlock #30 Common (Output)
10 (Lock - Output) H/5 GR/BLK Lock #30 Common (Output)
14 (Door Switch) Not Connected
16 Horn H/12 BRN Horn Honk Output
15 Ground Ground Connections listed below:
H/7 VLT/BLK Lock #87 Normally Opened- input
H/9 VLT Unlock #87 Normally Opened - input
H/11 BLK Ground Input
H/3 BLK/WHT Dome Lt Supervision Input -
(Setting to Negative)
