pyle pwd701 critical
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135778
Printed Date: April 09, 2026 at 4:04 AM
Topic: pyle pwd701 critical
Posted By: arlind86
Subject: pyle pwd701 critical
Date Posted: January 10, 2014 at 11:38 AM
Hello Everyone,
I'm trying to install the PWD701 on my father's 1995 Jeep Grand Cherokee (I6 4.0L) which also has OEM power locks & alarm.
I am having a hard time with the Pyle Starter/Alarm because, well;
1- No brake wire on the starter
2- No disarm wire
3- No Tach wire
Can someone help me out here please?
I can figure out everything else but it's a bit concerning to me. How can I start the car when there is no DISARM wire. I have already located the disarm wire (-) in the jeep.
The starter has an optional hood pin or trunk wire(-) which shuts the car off and disables the starter when touching Negative.
I could use a relay and use it on the Brake wire(+) to the starter when under way.
I'm also not sure about the Tach wire. I assume this might be a TACHLESS system but have yet to test it.
FYI -Link to Pyle Manual
https://www.pyleaudio.com/sku/PWD701/4-Button-Car-Remote-Door-Lock-Vehicle-Security-System
Constant 12V+     RED / White      Ignition Switch Harness
Starter      Yellow/Blue      Ignition Switch Harness
Ignition      Blue/Gray      Ignition Switch Harness
Ignition 2      RED / Black      Ignition Switch Harness
Accessory      ORANGE / Black      Ignition Switch Harness
Tach      Gray/White      Coil
Brake Switch      White      Brake Switch
Trunk Pin      n/a      Works with Dome Light
Parking Lights      Blue/Red (+)      Left of Steering Column
Head Lamp      Tan/Black (+)      Light Switch
Hood Pin      n/a
Factory Disarm      Purple / YELLOW (-)      Driver's Kick Panel Black Connector
Door Trigger      Yellow (-)      Driver's Kick Panel
Door Lock      ORANGE / Purple      Driver's Kick Panel Black Connector
Door Unlock      Pink/Purple      Positive Trigger or Red Connector Passenger's Kick
Horn Wire      Gray/Orange (-)      Steering Column
Windows Up      LF=White, RF=BROWN / White, LR=Gray/Black, RR=Gray/Black
Windows Down      LF=Light Blue, RF=PURPLE / White, LR=GREEN / WHITE, RR=GREEN / WHITE
Posted By: bl4ck3d0ut
Date Posted: January 10, 2014 at 3:19 PM
This is a security system only, no remote starter on that unit.
