2010 toyota rav 4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135988
Printed Date: April 05, 2026 at 9:51 PM
Topic: 2010 toyota rav 4
Posted By: ziggyb222
Subject: 2010 toyota rav 4
Date Posted: February 04, 2014 at 8:48 AM
Put in a Avital 4103 in a 2010 Rav 4. Used the Idata ADS-AL-CA flashed with the ADS-AL(DL)-TL1 firmware...When programming the module I get a red flashing light...never get a green light...not used to using these modules...any ideas????
Posted By: triniforever
Date Posted: February 04, 2014 at 2:26 PM
Check the metal shaft of the key close to the black plastic head what do you see stamped on there a DOT? Or a G?
triniforever
Date Posted: February 04, 2014 at 2:45 PM
it was a dot...no g!!!
Date Posted: February 04, 2014 at 2:58 PM
Did you confirm you got the right TXCT , CODE , CANH,CANL wires ? How are you programming the module ? And did you do DTD or WTW? Or better yet list the connections ! That install should be very straightforward .
triniforever
Posted By: diggedy
Date Posted: February 04, 2014 at 4:20 PM
try using the grey valet key I have run into this issue on a few Toyotas using idatalink
Diggedy
Date Posted: February 04, 2014 at 4:59 PM
txct and code pink and green at the immobilizer...white and black Can h and can l...hardwired it and flashed for it...put key in..turn on and get the red light on the module..vehicle remote started with the key in the ignition...gonna double check all connections on thurs...thanks
I will see if the customer has her gray key also!!!
Date Posted: February 04, 2014 at 5:36 PM
When you first connect the module the green LED blinks on and off at a steady rate push the programming button once and let go the LED blinks with two flashes at a steady rate this is W2W mode push the programming once more and hold after a couple seconds the LED will turn on solid and turn off the module is now ready to be programmed with the key
triniforever
Date Posted: February 06, 2014 at 1:28 PM
I had the wrong pink wire at the immobilizer harness...Works perfect now...Thanks for all the help!!!!
