viper responder 1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136111
Printed Date: April 10, 2026 at 7:53 AM
Topic: viper responder 1
Posted By: lucasoil4u
Subject: viper responder 1
Date Posted: February 20, 2014 at 12:46 PM
I have a viper responder 1 in the wifes 2013 mazda 3. Its in virtual tach mode. I know not good. Its been working fine forever. The battery died and i installed a new battery and reset the brain. Now the car will crank for .1 of a second. Im going to run a tach wire this weekend and see if that fixes it. If not does anyone know if the avital 4113 brain and the reponder 1 brains are the same? Thanks
Date Posted: February 20, 2014 at 1:29 PM
How do you RESET virutal tach settings?
Posted By: blanx218
Date Posted: February 20, 2014 at 3:27 PM
You can only adjust virtual tach with a bitwriter. What do you mean by reset the brain? Virtual tach is automatically learned.
Posted By: pentavolvo
Date Posted: February 20, 2014 at 4:06 PM
That car has over crank protection just do voltage sensing with 4 sec crank time
Date Posted: February 20, 2014 at 8:29 PM
The car does not have over crank protection . The voltage with the new battery is higher so the brain thinks it's running . I'm just gonna install the tach wire Saturday . Hopefully it takes care of it .
