dei 8613 for frunk and engine 93 mr2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136118
Printed Date: April 10, 2026 at 12:20 AM
Topic: dei 8613 for frunk and engine 93 mr2
Posted By: webb26
Subject: dei 8613 for frunk and engine 93 mr2
Date Posted: February 21, 2014 at 12:13 AM
I have a 3705v installed on my 93 mr2. The car has no frunk or hood pin switch. As of now I have the instant trigger input wired to my (-) on my trunk light. I tested it with the system armed then released the trunk lid, and found it to be functional.
So I plan to have my trunk light wire, dei 8613 on engine lid, and dei 8613 on frunk lid wired to the instant trigger input on the viper system. My question is when is it necessary to diode isolate, and would I need to in this situation?
Posted By: harryharris
Date Posted: February 21, 2014 at 4:43 AM
Diode together at the join, 2 X 1N4004, bands away from the 3705.
This is because if your hood switch were to fail, stress corrosion, etc., it wont force on the trunk light and drain your battery.
Test before boxing up.
Posted By: webb26
Date Posted: February 21, 2014 at 9:08 AM
Thank you for your reply. It is much appreciated. I'll stop by a radioshack and pick up some diodes. Just for the sake of argument, I would be fine without diode isolating the sensors, but in the case of failure if I didn't diode isolate there would be failure at other points in my car?
Date Posted: February 21, 2014 at 9:13 AM
This was the main point, if your hood switch were to fail, stress corrosion, etc., it won't force on the trunk light and drain your battery.
But there are many other uses for diodes, protection of components against spikes on relay shut down etc.
You must read the diode section here on this site.
Posted By: webb26
Date Posted: February 22, 2014 at 1:26 PM
Great thanks again. I'll give it a go when I get all my sensors in from shipment.
