viper 5901 into 94 celica
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136188
Printed Date: May 16, 2026 at 1:09 PM
Topic: viper 5901 into 94 celica
Posted By: ask92
Subject: viper 5901 into 94 celica
Date Posted: February 28, 2014 at 12:59 PM
First off I have a 1994 Toyota Celica GT Automatic. It should be relatively easy install, especially since I installed one in a previous celica(however i never got the remote start to work properly. I already have everything wired, but have not gone through the setup on the unit yet. If someone could browse over my connections and confirm they are right I would appreciate it.
posted_image
H1/1-------> No Connection
H1/2-------> Constant 12v
H1/3-------> Red on Siren (Confirmed working)
H1/4-------> No Connection
H1/5-------> Ground to Chassis
H1/6-------> No Connection
H1/7-------> No Connection
H1/8-------> Door Trigger
H1/9-------> No Connection
H1/10-------> No Connection
H1/11-------> Parking lights(Confirmed working)
H1/12-------> No Connection
H2/1-------> No Connection
H2/2-------> No Connection
H2/3-------> No Connection
H2/4-------> No Connection
H2/5-------> No Connection
H2/6-------> No Connection
H2/7-------> No Connection
H2/8-------> Tach signal on Diag port
H2/9-------> No Connection
H2/10-------> No Connection
H2/11-------> No Connection
H2/12-------> No Connection
H2/13-------> No Connection
H2/14-------> No Connection
H2/15-------> Hood Pin
H2/16-------> No Connection
H2/17-------> Brake switch wire
H2/18-------> Grounded(will connect to neutral safety once if get it to work)
H3/1-------> Ignition 1
H3/2-------> Constant 12v
H3/3-------> Accessory 1
H3/4-------> Starter wire(car side)
H3/5-------> Starter wire(key side)
H3/6-------> Starter wire(car side)
H3/7-------> Ignition 2
H3/8-------> No Connection
H3/9-------> Constant 12v
H3/10-------> No Connection
The lock and unlock are working fine as of now, and tonight I plan to hopefully test the remote start and put the car back together. If anyone sees anything they think is connected wrong please feel free to comment. Thank you.
Posted By: freqsounds
Date Posted: February 28, 2014 at 7:20 PM
H2/8 should be on H2/9
H2/18 if it's an automatic, connect it to Ground. If it's a manual, connect it to the parking brake.
H3/6 connect to +12V
Everything else looks good!
No question is stupid or not worth asking. You were once a noob, right? :)
