cm6000, 91 camaro, anomaly
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136250
Printed Date: April 11, 2026 at 1:23 PM
Topic: cm6000, 91 camaro, anomaly
Posted By: dezined
Subject: cm6000, 91 camaro, anomaly
Date Posted: March 09, 2014 at 3:36 AM
I recently installed a ft-6000as-cont in a 91 camaro. install went smoothly with one exception. When pressing the trunk pop remote button for 2.5 secs, the alarms disarms, and activates the starter. This is with PURPLE / white wire attached to typical relay setup for trunk pop. When PURPLE / white wire is disconnected, starter is no longer engaged.
The install manual states for + trunk systems to use pin 2 in cn1. This makes no sense to me as it is the starter wire. I'm wondering if it is a typo and they meant pin 6 in cn1.
If anyone can shed light on this issue, I would be grateful. I don't want to write the unit off as defective. I'm hoping it is an installation error.
Posted By: tedmond
Date Posted: March 09, 2014 at 8:04 AM
if you arent using positive parking lights, the wire is CN1 Pin 6 WHITE/ Green (adjust jumper under the cover)
the other wire that is a trunk negative trigger (which can be wired to a relay) is CN5 pin 2 PURPLE / white
check your options group 2, feature 4, is set to setting 1.
Never heard of it starting while popping the trunk. You might have something shoring the activation input
------------- Ted
Compustar Expert
Posted By: dezined
Date Posted: March 09, 2014 at 6:27 PM
I figured I'd post what the issue was for anyone else having the issue. I tapped into the trunk pop circuit at the wrong place. Ours is connected to the neutral safety switch, and this is what was starting the car. I tapped in right after the trunk pop relay, and everything worked perfectly.
