Clifford Solaris Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13644
Printed Date: May 13, 2026 at 6:45 AM
Topic: Clifford Solaris Problem
Posted By: rob_
Subject: Clifford Solaris Problem
Date Posted: May 17, 2003 at 3:17 PM
I was moving some wires in the engine compartment, specificially those that run to the back of my siren.  When I moved some of the wires one of them broke off from inside the tape.  I took it apart with the intent to reconnect the wire to the end that broke off.  The wire is the ground wire coming off of the siren, it had 2 butt connectors connecting what I *think* is some sort of diode.  Its broken and I am able to read what I beleive is U28 on it.  Its a small round black tube.  Not sure exactly what it is but im going to guess its a diode.  The follow pictures are of it attached to the butt connector.  Tried to get as close as possible.
https://www.rickone.com/rob/diode1.jpg
https://www.rickone.com/rob/diode2.jpg
https://www.rickone.com/rob/diode3.jpg
Rob
Posted By: rob_
Date Posted: May 17, 2003 at 6:13 PM
Follow up:   Was able to decipher diode.
