2005 hyundai sonata as1414/1424
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136557
Printed Date: April 02, 2026 at 6:02 AM
Topic: 2005 hyundai sonata as1414/1424
Posted By: misterbmw
Subject: 2005 hyundai sonata as1414/1424
Date Posted: May 03, 2014 at 10:50 PM
Hello!
I have a next problem, battery in my RS died and i put a new one.
And now I have to link transmitter with RS module in my car.
I was trying next:
Case 1
posted_image
Case 2
posted_image
Parking lights stays on for 20 sec. as they should in programing mode.
In both cases, there are no reaction of parking light after holding LOCK button on RS.
I think my RS do not transmit signal.
My RS (red LED):
posted_image
M.T/
Posted By: sparkie
Date Posted: May 04, 2014 at 8:23 AM
Did you check the battery of the remote. Make sure it is good. Just because the remote's LED works means nothing. Many non name brand batteries are nearly dead when sold. Take the batteries out of the remote and check with a volt meter. Do you have a second remote to try to program?
sparky
Date Posted: May 04, 2014 at 10:15 AM
Yes I checked battery with voltmeter its shown 12V.
I don`t have another RS to check only one.
M.T/
Posted By: sparkie
Date Posted: May 04, 2014 at 7:57 PM
The remote may be defective. Those remote starters don't loose programming when the batteries in the remote go dead. I assume we are talking about the remote's battery correct? If the battery in the vehicle was disconnected, you may have created a logic lock with the module. Unplug the 6 pin main power to the remote starter for 10 seconds and then reconnect it to clear the logic problem. The only other thing is to check the remote for bad connections on the circuit board. There are only a few which can be resoldered.
sparky
