g35, viper 4105vb and dball2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136649
Printed Date: February 14, 2026 at 9:37 AM
Topic: g35, viper 4105vb and dball2
Posted By: beakerss
Subject: g35, viper 4105vb and dball2
Date Posted: May 15, 2014 at 6:37 PM
Good day, I have installed the viper 4105vb and it is working with no problem, I am taking the transponder bypass with key, and installing the DBALL 2, I was going to d2d the big connections but i am lost and not sure what to do the other wiring. The box did not come with instructions on how to install it. Can someone please enlighten me on how to install the dball 2 with an installed remote start. Any assistance is greatly appreciated.
Posted By: kreg357
Date Posted: May 15, 2014 at 9:09 PM
Not really enough info to help you.  The early G35's ( 2003 &2004 ) had the older style BCM. The newer G35's ( 2005 & 2006 for the sedan and 2005 - 2007 for the coupe ) had the newer style BCM.  Would help to know the year and model.
Aside from that, did you get the DB-ALL2 flashed with the correct ( 402.NISS01 v1.04 ) firmware?
Here is a link to the DB-ALL2 w/NISS01 firmware install guide :  https://www.xpresskit.com/DocumentDownload.aspx?documentid=9211&productid=553&firmwareid=5372  Fairly easy car to do.  The BCM is in the driver kick panel.
Here is a photo of the BCM from a 2004.5 G35x with the newer style BCM :
posted_image
Posted By: beakerss
Date Posted: May 17, 2014 at 8:22 PM
This worked and i do thank you very much, i did forget to mention it was a 2003. Now If someone could please help me on this issue. I purchased a PKE 2102t, hooked it up via d2d am can get the module to mention the fob and send the information via the hookups. I have not hooked the wires up via the 10 wire hookup as they are not needed (not sure). The remote start works perrfect and the unlock. the module does receive signals via lock and unlock, the remote does try to lock and unlock temotely by itsself. Am i missing something, i have tested the antenna connections, the battery, and even programmed the modules. Can someone please help so i really don't feel like i wasted my time and the money.
