1983 camaro ohio mile project
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136729
Printed Date: May 15, 2026 at 1:17 PM
Topic: 1983 camaro ohio mile project
Posted By: brick0987
Subject: 1983 camaro ohio mile project
Date Posted: May 31, 2014 at 6:40 PM
ive installed factory actuators and switches but ive got new relays, not the factory and im not sure which switch and motor type i have?
Posted By: racerjames76
Date Posted: June 04, 2014 at 9:29 AM
Unless you bought the entire harness/relay kit from a donor car you will be better off just making the switches ground switch your new relays.
posted_image
The purple and blue pin 30s will go to the 2 wires going to the factory actuators. Polarity only matters that both actuators are wired the same way so they react the same way.
The green and blue alarm lock/unlock (-) inputs (labeled as outputs in the photo) will go to your switches. There should be 3 pins on the switches. One Common pin and 2 normally open pins. Pretty easy to figure out which terminal does what after that. As long as you fuse the 12v line going to the relays you cant mess this up. For factory actuators of this vintage you will need either a 15a or 20a fuse. Start smaller and if it blows go up to a maximum of 20a If the opposite action happens from the button you pressed simply swap the inputs to the relays or swap the polarity at the actuators. Which ever is easier.
To master and control electricity is perfection. *evil laugh*
Date Posted: June 04, 2014 at 9:32 AM
To clarify the above info is if you do NOT use any of the factory wiring save for a few inches at the switches and at the actuators. Nothing else should be attached to this circuit.
Date Posted: June 08, 2014 at 10:11 PM
Ok thanks a little assurance goes a long way, but now if I install a keyless entry would it just go to either terminal 85 and 86 or do I need separate relays?
Date Posted: June 08, 2014 at 10:37 PM
If the keyless unit puts out -ve then yes. You will just use that to trigger the same relays in place of the switch. Any -ve input will work be it from the switches or a keyless unit.
Date Posted: June 09, 2014 at 8:04 PM
Ok thanks I've been over thinking it, it took me longer to run the wires from the relay center to the doors than anything, I was thinking I needed either resistors or diodes in the circuit but I don't think it applies to the door lock actuators, correct me if I'm wrong please!!
Date Posted: June 09, 2014 at 8:18 PM
Nothing else needed
