Cooling Fan Issues After Alarm Install, 95 Honda Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13680
Printed Date: May 13, 2026 at 3:59 PM
Topic: Cooling Fan Issues After Alarm Install, 95 Honda Accord
Posted By: Accordguy
Subject: Cooling Fan Issues After Alarm Install, 95 Honda Accord
Date Posted: May 18, 2003 at 4:29 PM
Hi everybody,
I have a 95 honda accord 2.2 vtec engine. I just recently installed an alarm with remote start but I dont have the remote start hooked up though just the alarm.
I tryed to hook the remote start up but didnt work so i am going to get that professionly installed. I hope I didnt fry any of my wires. I checked the relays and fuses there all still good. If I did screw up the wireing what would I need to fix it?
My cooling fan only comes on when my car is off. When I turn my air condioner on both fans come on so I know the fans work.
My fan uses to come on when my car was on just randomly. Now if dont come on at all with my ignition on. so when my car is idleing the temp gauge goes up past the half way mark.
I was thinking that maybe my sensor could be bad? I just changed my theromostat. can somebody help???
Posted By: cpgoose
Date Posted: May 19, 2003 at 9:28 AM
Not sure if your problem is the same as the problem I had, but it was similar. In my Acura Integra ('93), the cooling fan didn't come on when I had the a/c on, but then it would come on whenver it wanted (especially when the car was off) and would kill my battery. Someone suggested the "Cooling Fan Relay" or "Cooling Fan Timer Module"...something like that. After changing a bunch of things (and nothing working), I changed that module, and everything works fine now. It looks like a black plastic box, maybe a little bigger than a pack of cigarettes. It was located behind the radio in the dash, to the right side. When I just touched the old one, the fan would turn on, and if i hit it again, the fan would turn off. So I knew that was the problem. It cost about $150 or so...and everything works now.
By the way, maybe if you describe the remote starter and your problem, we can help you install it.
Date Posted: May 19, 2003 at 11:25 PM
well I have a crimestopper 2006 2 way fm pageing. if you got to crimestoppers.com and click alarm click on one of the alarm names and go to manual go to cs-2006 go to the last page thats the diagram of alarm. Do I just tap them in to ignition? and it should work right?
Date Posted: May 19, 2003 at 11:47 PM
Which wires go with which? I have a 95 honda accord.
Honda Accord diagram
starter BLACK/ white ignition switch
12v constant White ignition switch
ignition BLACK / YELLOW ignition switch
heater yellow ignition switch
accessory WHITE/ black ignition switch
Alarm diagram
Brown IGN+ Secondary Ign(if needed)
Yellow IGN+ Ign 1 (Primary)
Orange Acc+/Ign 2 Heat/air
Violet Starter+ Starter
PLEASE HELP!!!!!!
Posted By: cool_greg
Date Posted: May 20, 2003 at 6:21 AM
Honda Accord diagram Alarm diagram
starter BLACK/ white Violet Starter+
12v constant White
ignition BLACK / YELLOW Yellow IGN+
heater yellow Orange Acc+/Ign 2
accessoryWHITE/ black Brown IGN+
Hope this helps out
Greg
Date Posted: May 21, 2003 at 1:09 PM
thanks I will try that! thanks for the help guys
