lincoln mkz 2k10 viper 5704
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136857
Printed Date: May 14, 2026 at 2:12 AM
Topic: lincoln mkz 2k10 viper 5704
Posted By: solarys
Subject: lincoln mkz 2k10 viper 5704
Date Posted: June 22, 2014 at 6:29 PM
Help Needed! Viper alarm will not arm or disarm. Nor will with the remote start work. The blue LED does not light up at all. Any suggestions? All suggestions will be greatly appreciated. Thanks in advance.
Posted By: howie ll
Date Posted: June 23, 2014 at 1:49 AM
Check the voltage across red and black on H1, look at the brain, has anything become detached such as green antenna plug? Also look at the control centre black plug.
Posted By: solarys
Date Posted: June 23, 2014 at 7:07 PM
Thxs for ur response.    I can now arm the alarm, but I have to press the function key first. Plus, the driver side lock does not respond to remote, the other three locks do. Any suggestions?
Posted By: howie ll
Date Posted: June 24, 2014 at 1:05 AM
Your remote is locked see owner's manual.
