acura 3.5rl with python 871xp , tbxkey
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136860
Printed Date: May 13, 2026 at 11:10 PM
Topic: acura 3.5rl with python 871xp , tbxkey
Posted By: pmendoza502
Subject: acura 3.5rl with python 871xp , tbxkey
Date Posted: June 23, 2014 at 4:54 PM
I have an problem with the remotestart inconsistently starting the car.
I have made sure the key in the TBXKEY starts the car, made sure the jumpers are in their right places, and tried to make sure the wires are all in their right places but im not an alarm expert and despite having installed a number of stereos, amps, head units and subs, along with air suspension management systems, alarms still feel "over my head"
below are pics of how the TBXKEY is installed- I apologize in advance if these pics are not clear...
posted_image
posted_image
posted_image
It will oddly work once in a while, and i have a feeling that long black wire is the culprit. earlier today i touched my key to said black wire and tried to remotestart the car and wala! it worked! but my following attempts from outside the car fail in starting the car...
Posted By: howie ll
Date Posted: June 23, 2014 at 5:47 PM
That loop needs to be much more tight around the ignition switch, also those two blue butt connectors?
1) They are far too big for those wires.
2)Use that method anywhere near me and you'd be shown the door, SOLDER..
Lastly the install looks a bloody mess.
Date Posted: June 23, 2014 at 6:06 PM
Yea i had the install done at a shop near by and did not install this myself, had i installed it myself believe me, it would look much better, and would only look like this during testing...
despite how tight the loop is around the ignition switch i still have the same problem... would it help if i were to remove the plastic surround of the loop wire? or do i need to do something with that long black wire???
Posted By: howie ll
Date Posted: June 23, 2014 at 6:28 PM
Then I apologise, of course first answer would be to go back but looking at that install???
What's the long black wire for? What's it attached to?
Date Posted: June 23, 2014 at 8:06 PM
It is one of the three black wires that comes from a 3 pin connector that is plugged into the tbxkey. it is currently connected to a blue / YELLOW wire.
Date Posted: June 25, 2014 at 12:56 PM
What else can cause the remote start to function so infrequently?
Date Posted: June 25, 2014 at 2:46 PM
So In an update, I was playing around with that long black wire and ran it to its length away from the TBXKEY and the key cylinder so as not to pick up any interference and tried to position the loop closer to the front of the key cylinder and WALA! IT WORKED!!!
Now Im debating weather to remove that plastic surround on the loop and just use a few pieces of electrical tape to keep it together while having some wires exposed to better transmit the signal to the key cylinder. Also i am now debating whether or not to replace the bypass module with a better one that doesnt require the loop for consistency's sake, any recommendations?
Posted By: blanx218
Date Posted: June 25, 2014 at 3:33 PM
Hondas and acuras need the loop to be on the front of the transponder ring. not around the outside edge. It makes for a pain in the you know what when you try to put the shroud back on. You could always go the route of a data bypass module and eliminate that loop altogether. Depending on what year RL you have a PKH34 may work and its a Honda/Acura only module that never needs flashed, so no hassles with programming
Date Posted: June 25, 2014 at 3:56 PM
I have a 1999 Acura 3.5RL Will PHK34 work for me? and how difficult is the install?
