two diodes on parking light output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137091
Printed Date: April 05, 2026 at 6:34 PM
Topic: two diodes on parking light output
Posted By: 69-er
Subject: two diodes on parking light output
Date Posted: August 11, 2014 at 1:48 PM
I'm installing a keyless entry that has two diodes in parallel on the parking light output. This is a positive output to be connected directly to the parking light circuit, no need for a separate relay.
I'm assuming these diodes are for foreign cars to isolate the left and right light circuits. I'm installing it in a domestic car.
Based on a quick search here it looks like I won't need them. I shouldn't even need one diode for backfeed since the output from an internal relay.
Am I correct in all this?
Thanks!
Larry
Posted By: catback
Date Posted: August 11, 2014 at 2:15 PM
You are right, you can axe the diodes.
