2002 buick passkey 3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137707
Printed Date: April 09, 2026 at 11:59 PM
Topic: 2002 buick passkey 3
Posted By: ziggyb222
Subject: 2002 buick passkey 3
Date Posted: November 16, 2014 at 2:51 PM
Can the passkey three be bypassed permanately like the two and one systems...Thanks
Posted By: kreg357
Date Posted: November 16, 2014 at 6:37 PM
No.  Passkey 3 is transponder based while Passlock 1, Passlock 2 and VATS is all resistor based.  It can be bypass permanently with a programmed chip from a working key and some hot-glue.  posted_image
Posted By: kreg357
Date Posted: November 16, 2014 at 6:44 PM
Replacement PK3 keys are cheap and programming a new one to the vehicle is an easy DIY.
Date Posted: November 16, 2014 at 6:48 PM
I have a programmed key....it is the typical no start on occasion. Customer cannot afford to replace parts and the car has 200 thousand on it...
Posted By: kreg357
Date Posted: November 16, 2014 at 6:58 PM
Perhaps an ADS TBSL PL programmed & installed and with the GWR input triggered by the vehicles (-) keysense wire.  Only have to use
plain metal hardware store keys from then on...   A $50 "fix".
