2013 rav4 wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137884
Printed Date: March 20, 2026 at 8:18 AM
Topic: 2013 rav4 wiring diagram
Posted By: whipaway
Subject: 2013 rav4 wiring diagram
Date Posted: December 06, 2014 at 4:21 PM
HI, I am looking for any of the wiring diagrams/charts for the 2013 RAV4.
Yes, I know that a pictorial exists for the installation of a remote start, but no wiring info for door switches, etc are given.
Specifically I am looking for wiring info for an alarm system installation.
Posted By: kreg357
Date Posted: December 06, 2014 at 5:15 PM
For vehicle wiring, here are some sources :
Here is a link to Bulldog Security :  https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Here is a link to Ready Remote :  https://www.readyremote.com/main.asp
The above site's info does not list all the individual door trigger wires, so here is that specific info :
Driver Front Door Pin           WHITE (-) DASH FUSE BOX WHITE 40 PIN CONN, PIN 40
Pass Front Door Pin   BLUE (-) REAR OF DASH FUSE BOX WHITE 30 PIN CONN, PIN 19
Driver Rear Door Pin WHITE (-) REAR OF DASH FUSE BOX WHITE 30 PIN CONN, PIN 1
Pass Rear Door Pin   YELLOW (-) REAR OF DASH FUSE BOX WHITE 30 PIN CONN, PIN 6
Trunk Pin   LT GREEN (-) DASH FUSE BOX WHITE 40 PIN CONN, PIN 33
Hood Pin    RED / WHITE (W/ OEM RS ONLY) (-) WHITE 5 PIN CONN, PIN 4 ABOVE DRIVER KICK   ***
***  Your 2013 LE won't have the factory hood pin.
If you don't want to hard-wire everything, iDatalink has come out with new firmware for their ADS AL-CA bypass module that
will do most of the work for you with only a few connections to the car.  Here is a link to the ADS AL-CA w/ DL-TL8 firmware :
https://cdncontent2.idatalink.com/corporate/Content/Manuals/DL-TL8/ADS-AL(DL)-TL8-EN_20141120.pdf
Posted By: tedmond
Date Posted: December 06, 2014 at 6:16 PM
don't forget to diode isolate, or you can use the:
dome light gray (-) white 56 pin plug, pin 35 @ fuse box plug 3D
Ted
Compustar Expert
