12volt+ source
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13797
Printed Date: May 14, 2026 at 10:44 PM
Topic: 12volt+ source
Posted By: sach_deva
Subject: 12volt+ source
Date Posted: May 21, 2003 at 1:52 PM
Hi!,
Is it safe to get 12 volts for the alarm, door lock relays, illuminated entry, and trunk actuator from the 12 volt source from the ignition switch harness?
Ricky
Posted By: draasch
Date Posted: May 21, 2003 at 3:57 PM
what is the yr make and model of car?????
you can get the alarm power fron there.
and the trunk release power.
you might over load the your hook ups.
i would look for a second power source.
make sure you use fuses at the hook up point.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: May 21, 2003 at 5:39 PM
I am asking this question in regards to a 1990 VW Jetta
Posted By: auex
Date Posted: May 21, 2003 at 8:27 PM
I don't see why there would be a problem. The main ignition wire should be fused high enough to run the car when the key is on that the alarm should function fine when the key is out.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
