compustar cm7200 and blade al not startin
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138030
Printed Date: April 08, 2026 at 1:02 PM
Topic: compustar cm7200 and blade al not startin
Posted By: spincycle
Subject: compustar cm7200 and blade al not startin
Date Posted: December 23, 2014 at 12:45 AM
Hi, I have a 2015 Subaru Outback with PTS that I just installed the compustar CM7200 with blade AL in. It was my first remote start install, and my first time ever working with a Compustar/blade al I was able to program the smartkey to the unit, following the instructions. I was also able to setup the key fob to the remote start.
When I go to start the car remotely, the 2g9 remote gives me a red flash on the remote, and it does not start. The unit in the car clicks 3-4 times, then waits a second and clicks again. No attempt to start the car occurs.
I used the low voltage ignition plug for the car, except for the ignition2 which I used the high voltage, since it was the only connection that had this. Could this be the problem? should I have used all high voltage?
Thanks for any assistance!
Date Posted: December 23, 2014 at 5:03 AM
Forgot to mention, locks and power liftgate are functioning.
Posted By: prdjr165
Date Posted: December 23, 2014 at 5:18 AM
not sure on the CM7200 but most compustar units have a green wire inside that have to be cut for automatic trans vehicles before they will start.
Posted By: tedmond
Date Posted: December 23, 2014 at 7:09 AM
you shouldn't be mixing the ignition harnesses. either use low current or high current. also check the loop inside the unit. cut for auto
------------- Ted
Compustar Expert
Date Posted: December 23, 2014 at 8:01 AM
I cut the manual/auto wire inside the unit. The ignition is deffinately low voltage, but i needed the ignition2 that the low voltage did not have...should i switch it all to the high voltage?
Date Posted: December 23, 2014 at 3:33 PM
Ended up the problem was that I needed to learn the Tach, so start the car, press the break and click on the remote start button.
It now starts the car.
Set's off the alarm when I try to open the door, so I have to work on that next.
