99 grand cherokee avital 4103
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138142
Printed Date: April 02, 2026 at 9:57 AM
Topic: 99 grand cherokee avital 4103
Posted By: 99wj539918
Subject: 99 grand cherokee avital 4103
Date Posted: January 04, 2015 at 8:47 PM
My wife bought me the Avital 4103LX Remote Starter for Christmas this year and finding Installation Instructions has proven to be difficult. My Jeep doesn't have a SKIM (Sentry Key Immobilizer Module) so I don't need a DB-ALL. I've searched and found most of what I need, but there are still a bunch of things I'm not sure about...
1) What does the DB-ALL H14/2 (Violet / YELLOW) to OBD2 Pin 2 do? Do I need to wire anything to that Pin 2?
2) The DB-ALL H12/9 & 8 (Violet/Green, Violet/Brown) that connects to the headlight switch Pin 11 (Yellow), is there a connection that needs to be made from the 4103 to the headlight switch Pin 11 (Yellow)?
3) Where do I wire the H1/6 (Brown) Horn Output to? All I've seen is "at horn switch." Before or after the horn relay?
4) Are all grounds better to be run to a single ground via a cable lead right from the negative terminal run through the firewall or just use existing chassis grounds?
5) On the 4103 I'm supposed to wire H1/9 (White) Light Flash Output to the DB-ALL Pin 10 (Pink/White). Is that not needed without the DB-ALL? Also, it says I'm supposed to "Set to Positive," what does that mean?
6) On the Satellite Harness I see that Pins 1 and 3 for the Status and Starter Output go to the DB-ALL H10/10 & 8 Status and Starter Input. Without the DB-ALL where should those connections be made?
7) Also on the Satellite Harness Pin 2 is for the Accessory Output, I can't find anything on where that should be wired into. What does that do and where should I wire that?
8) The H2 Pins 1 & 2 are wired to Ignition Switch wires Dark Blue and Yellow and it says "And DB-ALL 10 Pin Pink and Violet." I imagine I should be fine with just wiring H2 Pins 1 & 2 to the Ignition Wires, but I just wanted to make sure.
9) The Door Lock/Unlock Harness is supposed to be wired to the DB-ALL 10 Pin Blue and Green. Where should I get the Lock/Unlock signal for those wires on the Door Lock/Unlock Harness from?
10) On H3 Pin 3 (Brown) Brake Input Shutdown Wire I guess gets connected to the brake switch? Any help with that?
11) Is there a way I can have my rear defroster wired up to the remote start?
Wow, I think that's it for now. Thanks guys, any help would be greatly appreciated. I'm not new to wiring things up, but this is my first remote start install.
Date Posted: January 04, 2015 at 8:48 PM
Forgot to mention...
1999 Jeep Grand Cherokee
Posted By: Chris Luongo
Date Posted: January 05, 2015 at 6:41 AM
I've done these mostly with the FLCAN, the FLDL1, and long ago, the old 455J I think it was called back then. So I might be a little off about the DBALL information but I'll try.
1: That would be to control the car's door locks through the data bus in the car.
2: Readyremote.com should have the resistance value you need. The Avital white (with the jumper installed in the negative trigger position) will go through a resistor and to the car's parking light wire.
Personally, I just pop out the car's parking light relay (just above the fuses), test for the straight negative-trigger wire at the relay, and tap my remote starter's parking light wire in there. This way, no resistor needed.
NOTE: Don't try to power up the positive parking light wire in this car. Stuff will break.
3: Two square connectors above the fuse box. In the left of the two connectors, gray/orange is horn. (Should be in steering column too; I never looked there.) And you'll be looking for a negative-trigger wire; it's before the OEM horn relay.
4: I've always used one of the 10mm bolts holding the big metal thing on around the ignition wires. A lot of people would recommend going down to the driver's kick panel and directly to body metal. In either case, no need to go directly to the battery for ground.
5: Haven't used the DBALL, but "set to positive" they mean which way you're supposed to put in the little jumper that's taped to the Avital brain.
But your two options are essentially this: Configure Avital for positive parking lights, connect that to the DBALL, and then the DBALL does you the favor of handling the resistance for you in the car.......or, skip all that (especially if not using DBALL) and wire up the Avital to the car directly to control the lights, as in #2 above.
6: Shouldn't need to connect these to anything if not using a bypass module.
7: That's to trigger extra relays if you have a car that has several separate accessory wires. Shouldn't need it for your installation.
8: That sounds right.
9: This is the part that'll surprise you.......your car doesn't have any easy-to-connect doorlock wires anywhere inside the car.
There are some diagrams if you do a search....fish wires into both front doors, wire up two relays in each front door.....lots and lots of labor. I've never done it myself, and I wouldn't want to.
So basically, just because you don't have the gray Sentry Key, you need a module anyway just to do the locks.
If you can find an old-stock 455J you might find it cheap. Or else that DBALL, FLCAN, FLDL1, EVOALL.
NOTE: Modern bypasses require that they be programmed with the correct firmware for the car being worked on. If this is something you're going to buy online, make sure you find a seller who knows what he/she's talking about and get a module with your firmware already on it.
10: Yes. On the Grand Cherokee, you can actually give the brake pedal switch a slight twist and it comes out to make the wire easy to get at.
NOTE: These brake switches are fragile. I had one come apart in my hands once. They're cheap at AutoZone and usually in stock.
11: Not sure. You might try searching the forum and see if someone else has tried it before.
